DLink DWL-g810 + Linksys WRT54G
Hi, Im trying to bridge a wired ethernet connection to wireless using a Dlink DWL-G810 connecting to a Linksys WRT54G Wireless AP/Router.
Problem is when it connects it works for a few seconds then comes on/off (mostly off) then kicks off other wifi clients - I have to physically reboot the router.
Has anyone else had this problem? Im running a non-standard firmware on the WRT54G but that wouldnt be the issue, would it?
News User
Michel Chamberland
Hey, I just figured out today how to fix this problem. What I did was i
went into the D-Link G810's configuration web page on your LAN (I think
the default is 192.168.0.30) and underneath the wireless tab there is a
super g drop down menu. For me that tab was set to Disabled. Then I
changed the option to super g with static turbo. This seemed to fix
the problem with the connection problem.
strike2006
Did changing the Super-G settings really fix the problem?
I've tried to do what you say, and it makes the bridge stop causing the
AP from dropping connections, but it also makes the bridge unable to
talk to the AP at all.
kevbo
