Hi
I am trying to hook up Dlink DWL-810+ to either Netgear WGT634U, FWG114P or WPN824. Prefer FWG114P. The case following is the same for any of these routers.
Case With all security and ACL off, DWL-810+ connects successfully. Switch on WEP security on, and DWL-810+ still connects successfully. But as soon as you switch on ACL on any of the Netgear routers mentioned, and type in the correct MAC address, the DWL-810+ fails to connect to that Netgear router. The MAC address used with same result as follows:
- Use DWL-810+ internet MAC
- Use DWL-810+ ethernet MAC
- Use PC MAC (as shown using ipconfig /all)
Can anybody point me to the right direction here, please?
Regards Leigh
CC to snipped-for-privacy@hotmail.com
