Dl 524 Help
I Have a Dlink 524 with b2 V 2.02 firmware, the problem is that I have to re-boot the router every 2-3 days as web browsing slows down to almost a complete crawl. The router is hardwired to a telewest cable modem on a 4MB connection. If I take the router out and connect directly all is fine. Any help appreciated.
TIA
Phil_M
On Sun, 20 Aug 2006 17:59:05 GMT, Phil_M wrote in :
Are you running peer-to-peer filesharing? That's a common cause of this problem.
John Navas
No not running anything like peer to peer
Phil_M
On Mon, 21 Aug 2006 09:20:03 GMT, Phil_M wrote in :
A simple work-around might be to put the router on a digital timer that power cycles it (say) at 3 AM.
John Navas
