I am using WIndows XP and I have a Wireless LAN network. I do not intend to connect to internet, everytime I login. I was suggested before to disable the wireless connection to disconnect from the network. However, sometimes I forgot to disable the wireless connection manually before I reboot/shutdown, and in the next login, my computer is still connected.
I did some search. I found that it was suggested to use a script under computer policy during shutdown, something like: net stop "Network Connections"
However, this script does not stop the Network Connection to start during login. In addition, even if I disable Network Connections service, my wireless lan connection is still active. The only way I could stop the wireless connection to function is to disable DHCP service. But, then I do not know how to turn the service on with a script or command line. I need to go to services.msc and manually start the DHCP service.
In brief, is there a script or task that I could use to disable the wireless network connection before reboot/shutdown?
Thanks.
