Hi, I have an unlocked BT 210 Router which i am having difficulty setting up. Everything goes fine up until i try and login at 192.168.1.1 where once i try and login the page keeps on refereshing itself until eventually just sticking at the logon page.
I have contacted madasafish (my isp) and they thought it could have be my firewall settings or something but i have tried disabling all of my computer security and i still had the same problem.
The comp screen appears in the bottom right of my screen saying it is connected and all the lights on the router suggest it is good to go so i am not sure what i am doing wrong.
Any suggestions would be greatly appreciated.
Many Thanks in advance,
Oliver
