Is there anything different about setting up a wireless network using a dialup modem to access the internet, if so, what?
Terry
Terry
have you read this article on the subject ?
Yep. Most broadband connections are full time with no conntects and disconnects. A dialup modem/router picks up the line when there's traffic, and hangs up when it's no longer busy.
Look on eBay for a 3com 3C888 or 3C886 Office Connect dialup router. It has everying in one package so you don't have to tie up a computah to do the dialing and PPP connection. Looks like there are a few available, but the prices are rediculous. It should be about $75US.
Also a Netgear RM356 for about the same price (or less).
There are also a bunch of Webramp modem/router models. Not recommended but they go very cheaply.
Incidentally, I use the 3com devices for backup if the DSL goes down.
You may want to check out the WiFlyer at
I had a 3com 3c886 for years. Works great.
