Hi gang,
I use a D-Link DI-624 Version C router and have upgraded my firmware many times over the past. I just updated from v2.70 to the latest v2.75 firmware.
With the new firmware, I'm now unable to set SSID Broadcast to "Disabled". I can choose Disabled and try to Apply the change, but upon restart, I revert to Enabled. In searching the router's Help section and online D-Link web support, I see that for SSID to be disabled, I must not use Extended Range Mode. I can find no other requirement for SSID to be disabled. I use Windows XPHome with the latest Critical Updates.
I have Extended Range Mode disabled but still can not disable SSID. The past v2.70 and earlier firmware versions for my DI-624 did allow me to disable SSID broadcast so the issue must be with the new v2.75 firmware.
Can anyone help me disable the SSID broadcast? Thanks.
