I think I've configured my DI-624 running firmware version 2.70 to support XP remote desktop.
I went into advanced: Enabled (Virtual Server) Private IP: I used the WAN IP address given under Status (this is the same address I got from: myipaddress.com) Protocol: Both Private Port: 3389 Public Port: 3389 Schedule: Always
However, whenever I try to connect I get the "The client could not connect to the remote computer"
Yes, XP is configured for Remote Connection and it does work because I can remotely connect as long as I stay within my LAN, i.e. I can do a remote connect to 192.168.....
but cannot when I go to the WAN IP address. I've tried pinging the wan ip address and that's fine.
Suggestions?
