Hi There.
I've been using a DI-624 for 2 weeks with no problems, and one day it was dead, it wouldnt turn on.. The power adapter 5v 2.5A wouldnt supply power also, I used a functionnal DI-604 Power adapter 5V
2A which Im pretty sure would work on a DI-624, but it do not turn on, so I got another di-624 from ebay @ 15$ no antenna no power adapter, I tried it with the new di-624 I got from ebay and it doesnt the same thing, I mean it doesnt do anything as it wont turn on... does the di-624 draws 2.5A and I really need a 2.5Amp to make it works or if its functionnal it should turn on with a 2A... ?Is it frequent for the di-624 to just stop working like this?.. should I go get a linksys instead ?
thanks
