DHCP Not Responding
Threaded View
Been using a public wifi connection here for several
months, no problem.
Suddenly, I have periods of a day or two that I cannot obtain an auto
assigned IP, then just as suddenly it will come back again. Logs show
packets are being broadcast to 255.255.etc same as they always have
been. But there is no router reply as when I do get assigned an IP.
Quite some time back, prior to this problem occuring, I connected to the
router which was  available to anyone who connects, no pw. It was set to
allow connections from anyone.
I tried using some randomly selected static IPs, but no joy.
Running XP. What's the most common cause of this and remedy?
Re: DHCP Not Responding
On 09/19/2010 18:51, justjohn wrote:
Lack of a subscription.  Pay the man.
Go visit a library or another place with free WIFI and see if you can
reliably connect to to the internet through that site's router.  If it
does then the manager of the problem site is most likely throttling your
laptop due to what they consider over use or possibly where you were
browsing to...
Other than that, I would open the access over the WIFI card and verify
the antenna cable connector is not loose for some reason.
Site Timeline
