Hello all,
We have a small network at work. Most machines are running Windows XP SP2 and on 100Mbps ethernet wired to our Windows Server 2003 machine. This server is a DHCP server for handing out an IP address, gateway address, DNS servers, domain names, proxy configurations, and other settings to each machine on the network when it boots. It works great.
We also have a Netgear WGR614v2 Wireless Router (with routing and DHCP serving turned off so it acts as a basic Access Point) connected to the LAN to give wireless access to a bunch of other machines. All the wireless machines have perfect wireless connectivity and work great if I specify the IP address, gateway and DNS settings manually.
While manual config works, I want to be able to use DHCP for all the extra settings the server dishes out. If I change the network config to get the settings via DHCP then perform ipconfig /release /renew the machine drops off the network. If I check the server's DHCP logs when a wireless machine requests an IP, there is a record of the request and the reply but the reply isn't reaching the wireless machine.
My best guess is that the DHCP reply packet is reaching the Netgear router and going no further. I have updated the routers firmware and checked and rechecked all the config options I thought could help.
Can anyone suggest what the problem might be, or better, what the solution might be?
Thank you,
- Jason
