I just got my Linksys WRT54GL wireless router, set it up and DHCP doesn't get my laptop right IP. Router IP is set to 192.168.1.1 and DHCP server is enabled (IP range 192.168.1.100-149). I can connect to it but internet wouldn't work cause it sets my parameters like this:
-IP address: 192.168.0.218 or 217
-Default gateway: 192.168.0.1
-DHCP Server: 192.168.0.200
-DNS Servers: 192.168.0.1 I have ADSL line and modem Sagem 3344. I deleted entry for DHCP on my modem and it's working in modem mode (no username and password set in setting). My connection is set from modem to router and then from router to 2 switches for desktop PCs (I manually set their IPs and internet works for them without problem). Also tried on other laptop and same story. If I manually set IPs on wireless adapter internet works with no problem. At first I thought that maybe if I upgraded firwmare problem would be solved but it didn't help. I upgraded to Tomato firmware version 1.10. If anybody has any idea what could be wrong I would really appreciate it :)
