DHCP and MAC address limitation
I have an SMC router and since I'm using a repeater, I have to broadcast the SSID. Because of that, I have set MAC address limitations. Even though it's enabled, and seems to work from a little testing, I still see a bunch of computers logged into my router via DHCP. What's the deal here?
Thanks.
-Ken
Ken
You may want to disable DHCP on the router and only use static IP(s). It may help your situation.
Duane :)
Duane Arnold
