Dell Dimension 4100 Wireless
Threaded View
Does anyone have a Dell Dimension 4100 desktop running wireless?
I put in a Linksys 54 G Wireless-G 802.11g PCI adapter and the Dell
doesn't see it.
Any help is appreciated.
Re: Dell Dimension 4100 Wireless
helmsman wrote:
I have in the past, unfortunately no longer. Worked fine though.
Did you install the software before installing the adapter? Mine was a
WMP54G.
What OS? What card? If Windows, you can get the driver package from the Linksys
webpile.
Larry
On Thu, 10 May 2007 03:21:32 GMT, Larry Finger
WinME. Linksys 54 G Wireless-G 802.11g PCI adapter.
Linksys e-mailed me this A.M. so I will get WUSB54G ADAPTER. It's
backward usb1.1 compatible and WinME compatible. I'll let you know if
it works.
On Wed, 09 May 2007 17:40:34 -0400, Pen
yes and talked to cisco. No cigar
OT, General question that shows my usenet ignorance:  why does one ask
that their message not be archived?
This means that in the future, others with the same problem will not
be able to follow this thread for a solution, right?
In other words, it's like a private help session?
I have wondered this as it turns up and decided not to answer when
somebody posts this way, but maybe there's a good reason....
Steve
Cuts down on a persons web presence.
WUSB54G + 16 ft USB cord = IT WORKS!
Thanks all.
Site Timeline
