For those of you waiting to update your WRT54G (or related models) firmware to DD-WRT:
DD-WRT v23 has been released today. It's no longer beta. "Brainslayer" is going to take a break for the rest of the year and then work on v24. There will be maintanance releases to v23, until v24 is released.
This does NOT work on the WRT54G v5. If you have the WRT54G v4 or the WRT54GL (v1), and you're starting with the stock Linksys firmware, make sure to load the MINI firmware first -- then load the complete firmware. (The old version, v22 does not work with the WRT54G v4 / WRT54GL.)
Make sure that you do a reset (hold the reset button for 30 seconds or, if you telnet into your router, do mtd erase nvram then reboot ) before and after you upgrade the firmware.
