I've successfully flashed my WRT54G to DD-WRT v23 mini and everything works great. Is it worth flashing to the Standard version? If so, should I use the Generic Binary with the web interface.
Thanks Larry
Thanks Larry
Larry Webb hath wroth:
Perhaps you should decide for yourself. See Feature List at:
Jeff,
The documentation for DD-WRT states for Linksys WRT54G/GS (any version) "...for webinterface flashing just use always the included generic binaries." I understood the non-generic files e.g. dd-wrt.v23_wrt54g.bin in the v23 Standard folder, to be for tftp flashing...
(The standard generic flashed to my V2 very nicely and the UI of the new firmware is very nice - I shall be PayPal'ing a small donation across to help keep this project alive.)
"__spc__" hath wroth:
Methinks that's slightly wrong. The .bin files can be used for either TFTP or Web based updates for the WRT54G. I've done it both ways. Web based for updates, and TFTP to recover after I bricked two routers. Same bin file in both cases.
However, I haven't tried it with the WRT54GS which might be different. All I know for sure is that the WRT54GSv4 has half the RAM and flash and is stuck with a (The standard generic flashed to my V2 very nicely and the UI of the
You can change the user interface to a wide variety of styles. The setting is at the bottom of the Administration page. I settled on "Wikar" as the easiest to see on my tiny laptop screen.
Ooops, I knew I forgot to do something.
To sound like Rush Limbaugh, dittos above.
Jeff have you heard seen anymore about DD-WRT23 and dhcpd working with Windows (XP) clients in particular has the SP1 beta shown signs it is working? I really need the DHCP service running before I can 'roll out' a router for a client. I have been to the website, but haven't actually seen anything saying the problem is actually fixed.
Thanks.
fundamentalism, fundamentally wrong.
BTW, BrainSlayer has been recommending to use DNSMasq for DHCP (check box on the main set up page).
DHCP - The issue which was fixed in Jan 23/25 is that when the PC (client) would try to renew its lease, the router would NAK it.. causing a disconnect before it comes back up and properly gives the PC the lease. So, it left a bunch of seconds of disconnected time for the PC. If you weren't doing something over the network at the renewal moment, you probably wouldn't have noticed it.
Both static and dynamic have been working for me - although sometimes it would take a bit to get a lease. I hear that the DHCP NAK fix, as a side effect, fixes the slow connections.
Thanks, could never figure out why dhcpd in Red Hat SUSE etc worked fine (for years), but not in DD-WRT. Bugs, sometimes you catch 'em and sometimes they catch you.
It didn't make any difference for my DHCP problems.
Fixed. 01/26/06 version is out.
Oh crap. Now: dumpleases -a doesn't work. The -a option has been partially removed. No big loss.
# dumpleases -h Usage: dumpleases -f -[r|a]
-f, --file=FILENAME Leases file to load -r, --remaining Interepret lease times as time remaing
v23-SP1-beta: big thanx for pierre belanger for providing my many patches
26.01.2006: google adsense added to the firmware (please discuss in the forum if you dont like it) firmware downsized a little bit again httpd code bug fixed (causes crashes under some not direct reproducable conditions) 25.01.2006: 0000653 DNSMasq as DHCP server NAKs lease renewal request - v23 sp1 16/01/06 0000386 Memoryleak httpd status page 0000589 PPPoE (standard) Connect on demand is broken 0000641 sp1: 13.&16.jan: All "Additional filters" turned ON by default16.01.2006:
0000170 WRT54G or GS hangs when (mtd erase nvram) then (reboot) from a telnet session 0000602 PPTP Internet connections drop due to ipables rules 0000301 WOL in WebGUI is out of Work 0000610 v23SP1: Rflow interface: web interface is broken dhcpc client interval fixes (connect now faster in client mode) dhcpc lease update fixes (does not disconnect on lease update anymore) wOL patch by Pierre Belanger implemented who finally got it to workI don't exactly love the fact that he aded Google Adsense... While, at least it's google and not some illegimate company, we're entering sensitive stuff on those setup pages... which they're using for context based ads.
There's a big discussion about it on the DD-WRT newsgroups... In the release notes, BrainSlayer actually asks people to discuss it. He said he's going to give it a few days to see whether he takes it out or not.
I haven't loaded Jan 26 versi> > Fixed. 01/26/06 version is out.
FYI on DD-WRT - from BrainSlayer:
"the ads will be removed tomorrow. for all other users
nvram set wanup=0 nvram commit and its disabled"
danr snipped-for-privacy@yahoo.com wrote:
Alas, I'm with you on this, I can't have this information leaking out to Google for ads. I understand he needs money, but there must be a better way. This is too insecure, after all this is supposed to offer firewalling ability...
But, the Jan 27th SP1 beta version breaks QoS. Until a new version is available, you can use the Jan 26 version and turn off the AdSense ads. Log into your router via telnet/ssh (root as the login and your normal router password as the password) and enter the following:
