I'm trying to get internet access in another building about 60 feet away.
I have an access point at the end of the first building. If I put a D-Link DWL-G820 adapter, hard wired to the remote computer with an ethernet cable, will it work?
On Fri, 21 Jul 2006 08:03:20 -0500, "Jim" wrote in :
It should.
The G820 works great for what you are describing. I have been using these units for several years now with great success. To make life easier for you change the G820 static IP from 192.168.0.35 (default) to match your AP address, i.e. 192.168.1.35. This way you can access and check signal strengths etc. without setting a static IP.
You can plug the G820 directly into a computer or use another router if you need more than one computer or wifi at the remote location. Supports VOIP quite nicely. With the standard antenna RP-SMA you can add directional and/or higher gain antennas.
If you haven't bought the unit yet I would suggest looking at the Meraki Minis 'Meraki'
repeater.
Sorry but forgot to mention this. With this D-Link appliance, and actually quite a few more of them, it doesn't like resetting.
From D-Link and applying to a lot of their gear including VOIP boxes
To avoid these problems if changing SSIDs etc BEFORE changing the SSID access the G820 and use Factory Reset, then go to step 5.
