There are 4 mutations of the G650 sold in the US plus the G650+ which is NOT sold in the US. Which one do you have and where?
Linux drivers appear to be available from Realtek.
Hi!
I have a D-Link DWL-G650+ PCMCIA card in my laptop. The card works fine, but when I unplug the power cord and start using the machine with battery power, it hang if I transfer any larger files or have constant traffic going on. After testing this problem, I have come to the conclusion, that the cause is the D-Link card. Has anyone else experienced this kind of behavior with wireless D-Link cards and is there any way to fix the situation? I already have asked the D-Link tech support about this, but they couldn't come up with any usable solution.
The laptop is running a Windows XP Home Edition (SP1) and the network card drivers are the newest ones available. The laptop is an HP Pavilion with Athlon-XP processor, which has some quite heavy power saving functionality, when running with the battery (could cause problems?).
Sincerely, Matti J. Kärki
Hi Matti,
I really don't know, but I can imagine, you could have asked the right question. Maybe you should try to turn off powersaving for the card. I think u know how to manage this;)
Hope this will fix the problem.
regards,
Jens
PS: I d> Hi!
but I am not sure if there are linuxdrivers for the G650...-sorry
I checked and it seems that the card is in "continuous access" mode. In other words, the power saving mode is off.
Well, I was reluctant to try the SP2, because I have had some problems with it in the past. But I installed it anyway and still the problem exists.
I also tested the card with Knoppix 2.6 and ndiswrapper. Unfortunately, the ndiswrapper didn't get the Windows driver working.
Well, I'm the one who is in a need of the Linux driver and I'm living in Europe and using G650+ card.
Thanks for the link. I'll need to check the acx100.sourceforge.net project...
OK. I was able to fix this problem. I changed the Wlan card to use 11b instead of 11g connection. This seems to prevent the hanging.
Does anyone else has experiences of this kind of behavior where forcing the card to use 11b will fix connection problems?
Yes, I have. I also noticed that when the laptop battery is almost out of juice, the computer may hang under heavy traffic even if the card if forced to work as an 11b card. So, now I'm suspecting that my laptop can't keep up the stable power at the PCMCIA slot.
Interesting. What does Ahteros have to do with D-Link cards? I thought that the G650+ uses Motorola or TI chipsets.
Well not rearly,
Do you have the newest driver installed from dlink website? If this doesnt work try the atheros 3.x.x driver.
I use this here because it supports althoug passive mode for capturing .)
If you dont know where to get it,feel free to email me.
Regards, Ingo
Well i havent looked at the chipset yet. I always use
Was the same with dlink 610. As they write on their website the realtek driver should work,but it didnt.
I patched the driver and voila passiv mode worked.
Seems the best built database on their website about cards and even normal pci cards that can handle other drivers.
Cheers, Ingo
Thanks for the info. I'll check the site.
Matti J Karki wrote in news:coevbg$2fa$1 @oravannahka.helsinki.fi:
D-Link has an unhelpful habit of using the same numbering system for
*completely* different products. It's easy to get them confused.The DWL-650, DWL-650+ and DWL-G650+ are all based on different wirless chipsets, and even between these (particularly the DWL-650) different chipsets have been used in different hardware revisions.
One clue lies in the "+". This is used to indicate so-called
802.11b+, the 22 Mbit/s speed achieved using PBCC modulation. This was invented by TI and there was some squabbling about it; although it is an option in IEEE 802.11g, (almost*) all wireless devices capable of this speed are based on TI devices.The DWL-650+ is based on the TI ACX100 The DWL-G650+ is based on the TI TNETW1130
Hope this helps
