D-Link DWL-G520 vs Linksys WMP54G for wireless card
Does anyone know which of the above 2 network cards would provide me with the strongest signal and reliability. I'm mainly using it for internet access.
tia Craig
tia Craig
On 1 Aug 2006 15:48:09 -0700, "Craig" wrote in :
There is little difference in range between standard Wi-Fi cards. If you need more range, get a card with an external antenna connector so you can use a high-gain external antenna.
In that case then I'll get the Linksys as I think it'll be more reliable. Do you know if they sell cables I can attach to the card and then connect the antenna so I can move the attenna maybe 10' from the computer to see where I can get the best signal.
Craig
On 2 Aug 2006 17:10:26 -0700, "Craig" wrote in :
That will only work with a card that has an external antenna connector, in which case you'll need to know what kind of connector the card has.
I'd personally avoid the losses of a 10' antenna cable by going with a USB adapter. (No losses in a USB cable.) Hawking makes one with a built-in high-gain antenna.
