Hello,
I am trying to set up some sort of encryption for my d-link, when I enter the details for WEP, there is a pop-up saying "Privacy type is set to WEP. Multiple SSID support will be disabled" and then the key that I have entered for WEP is erased, for the Access Control, I have not enabled Multiple SSID, any ideas? The same problem for WPA. There doesn't seem to be a working link for the UK D-link support website where I can raise some sort of eTicket..
Regards
