Hello all I am having no luck getting the camera to connect using wireless. I am able to use cat5 and plug it into the netgear router works ok. I have tried drippoing the speed down to 2mb have renamed the ssid to default on both the camera and the netgear.camera has fixd IP. I have also tried setting netgear router and camera to channel 6 any ideas regards
Peter
