Does anyone know the answer to this one.
I use to have a 900AP+ one antenna with a ANT24-1200 which worked great. Strong signals everwhere in the house.
I now have a 624+ set up as my WAP - I attach the ANT24 to one of the antenna sockets but my signal strength has dropped - this has been confusing me! Is it that I am only boosting half the signal output? Is that a correct interpretation?
If it is can I join the antennas internally within the box?
TIA.
