I am trying to create a wireless bridge between two Belkin F5D72314 Routers. One is being used as a Wireless Router, and the other has been configured to be used as an Access Point. I've entered the WLAN Address into the Wireless Bridge Page of the Router. I've also made sure that the SSID's are the same, and both the Access Point and the Router are on the same channel. For purposes of troubleshooting, I've turned off all encryption and other security.
I am able to sucessfully Ping the Access Point when it's connected to the Router via Ethernet Cable. However, when I disconnect the Ethernet Cable, it loses the connection.
What step am I missing here to complete the Wireless Bridge?
