Hi all I have 2 WRT54GS.I would like to create an a network with static
IP's (DHCP disable).On the first WRT54GS (Access point) iset everything
like an a normal Access Point, on the second one WRT54GS i set like a
client but notnihg happens.The 2 WRT54GS's cannot see each
other.Somebody can help me.
Thank you in advance.
P.S.The firmware of the WRT54GS is Sveasoft Alchemy 6.0 RC5A
