I want to copy and paste a random generated WEP/WPA file from the clipboard to my settings on the desktop and the laptop.
But even though I see the generated file on the clipboard, I can not save it in Save AS to a document or text file. And as long as I cannot do that, I cannot copy and past.
I'll assume Windoze XP Home. If you can "see" something in the clipboard, you must determine if it's ACSII text or a graphics screen capture. Try:
Open a blank new document in Notepad. Hit Edit->Paste. Did it paste?
If not, open a new drawing in Paint. Hit Edit->Paste. Did it paste?
If Notepad works, then you have a text document and you can do the save as thing. If only Paint worked, then you have a graphics capture and can also do the save as thing.
If you just want to capture the screen, do it this way instead of whatever you were trying to do:
Click the mouse anywhere inside the WEP/WPA window to set the "focus" on the proper window.
Hit . Nothing will happen.
Open a new drawing in Paint.
Edit->Paste. You should see a copy of the window you have captured.
