Our pc has recently started to get locked up by what appear in the system log as continuous strings of attempts to connect (to the router?). If I am lucky enough to have process explorer open at the time I can kill IE and the network adapter (v slowly!), otherwise the plug has to be pulled.
Last night I thought I had better do a check with PandaActiveScan on line. When it finally got to the end of the scan - 'no viruses' - some 2hr later, the processor was locked up again, but I was lucky enough to be able to shut off IE and the adaptor without having to pull the plug.
The error log showed a continuous chain of TCP/IP events for the whole time the pc had been on line doing this scan. These were all of the 'semaphore time out' type.
Interestingly, today, though there have been no lock ups so far, there have been two warnings in the error log to say that the 'TCP/IP has reached the security limit on the number of concurrent (incomplete) TCP connect attempts'.
Now, I had been looking for just such a 'limit the number of attempts setting', to try and stop the seize ups: why has the limit only now been imposed, and what does all this signify for our system? Is it likely to be a router/wireless problem, or is it an undetected virus or other hijack of some sort? (I have had some recent HiJackthis scans looked at at AumHa, but nothing untoward seemed to show up in the reports.)
Any enlightenment would be appreciated.
(We are using a D-Link DWL -G550+ adaptor, and a Buffalo WHR-G54S-1 cable router. XP Pro system.)
Cheers, S
