So in my last thread I got some good info. Now I have a new idea. Or two. I've got a router in one building and it runs a wire to another building with a old 10/100 switch. I was wondering if I could replace this switch with another router so the two routers are connected via cable but only one has internet. And both give a wireless connection. Would this work? Or would I have to get a router that supports the "up-link" thing like the 10/100 switch does? Or I could get an AP and plug that into the 10/100 switch gaining another wireless connection with the range I want throughout the property.
I was looking at a couple of routers and AP's. What do you think, and would they work how I want them too?
Routers: TP-Link TL-WR541G -- reasonable price or D-LINK DIR-635 -- pricey, but has N thinga which would match my laptops network.
APs: Netgear WPN802 -- expensive Netcomm Super-G NB600W -- very cheap
And do you think, if another router would work wired into the existing one, that just a cheap router with an antenna and 1w amplifier would be a good option? Would it give the most range?
Thanks.
