Hi guys,
I need help getting the console port on my WRT160N to work. I am using a TTL-232R 3.3V cable and minicom. I have soldiered up JP2 and believe that I have got the wiring connected correctly. I am using the following settings 115200 baud 8-n-1 with no flow control (hardware and software) but can not see the console at all. I am not sure what I should be seeing but believe that I should see some sort of boot sequence. Don't know what I am doing wrong but fortunately have not yet killed the router.
The exact cable I am using is a FTDI TTL-232R-3V3 USB to TTL with the FTDI driver. Anyone done this. What happened? Any help would be appreciated.
