Among the approved printers for it are my sister's HP Officejet 5610 - the one I'll be connecting to - and HP Officejet 6110
I'd like to know whether anyone has been successful in connecting HP Officejet 5610 to D-Link DPR-1260 wireless printerserver? By sucessful, I mean, get both wireless printing and wireless scanning working..
Trying to purchase D-Link DPR 1260 online got me to
"The scanner will not work using the software provided by the manufacturer. It only works over the browser interface with limited features." (This is from connecting to approved HP Officejet 6110)"
Btw, what does it mean by "it only works over the browser interface with limited features."
Another customer's comment in connecting with approved Samsung ML-1740 Laser printer: "My wireless router is a linksys WRT54GX2. The print server was extremely easy to set up on my network. I am using WPA security and have my SSID hidden. I did have to call tech support twice due to the normal steps of connecting a printer to the print server did not work." He continues .."Once you have the print server communicating with your network, connect your printer directly to your pc to get the drivers setup. Once this is done, move the printer to connect with the print server. Then you can just modify the printer port settings to point to the print server instead of going through the "normal" dlink method."
So
it seems that normal steps of connecting the printer on approved list to this print server doesn't work *or* the scanner (in the approved printer) will not work using the software provided by the manufacturer. Why?
