running
When its working, at a command prompt do an ipconfig /all, record the info. When its broke, at a command prompt type in ipconfig /all. Compare the
2 and respond with your findings.
running
2 and respond with your findings.I have the Dlink DSL-904 package (DSL-G604T and DWL-G122) running on Dell Dimension 8250 with windows xp. After about three days of running the router looses connection with the Internet and I need to go into the admin utility and restart the system. I have taken to restarting the system on a daily basis now but it is rather annoying. Does anyone know what might be wrong? Thanks
Here are the findings...top is working...bottom is not working.
Microsoft Windows XP [Version 5.1.2600] (C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\Owner>cd..
C:\Documents and Settings>cd..
C:\>ipconfig/all
Windows IP Configuration
Host Name . . . . . . . . . . . . : michael Primary Dns Suffix . . . . . . . : Node Type . . . . . . . . . . . . : Unknown IP Routing Enabled. . . . . . . . : Yes WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Network Bridge:
Connection-specific DNS Suffix . : Description . . . . . . . . . . . : MAC Bridge Miniport Physical Address. . . . . . . . . : 02-D0-D7-04-9D-48 Dhcp Enabled. . . . . . . . . . . : No IP Address. . . . . . . . . . . . : 192.168.0.1 Subnet Mask . . . . . . . . . . . : 255.255.255.0 Default Gateway . . . . . . . . . :
Ethernet adapter Wireless Network Connection 2:
Connection-specific DNS Suffix . : Description . . . . . . . . . . . : D-Link AirPlus G DWL-G122 Wireless U SB Adapter(rev.B) #2 Physical Address. . . . . . . . . : 00-11-95-8E-39-39 Dhcp Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes IP Address. . . . . . . . . . . . : 192.168.1.2 Subnet Mask . . . . . . . . . . . : 255.255.255.0 Default Gateway . . . . . . . . . : 192.168.1.1 DHCP Server . . . . . . . . . . . : 192.168.1.1 DNS Servers . . . . . . . . . . . : 192.168.1.1 Lease Obtained. . . . . . . . . . : 05 March 2005 10:30:47 Lease Expires . . . . . . . . . . : 05 March 2005 11:30:47
C:\>
C:\>ipconfig/all
Connection-specific DNS Suffix . : Description . . . . . . . . . . . : D-Link AirPlus G DWL-G122 Wireless U SB Adapter(rev.B) #2 Physical Address. . . . . . . . . : 00-11-95-8E-39-39 Dhcp Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes IP Address. . . . . . . . . . . . : 192.168.1.2 Subnet Mask . . . . . . . . . . . : 255.255.255.0 Default Gateway . . . . . . . . . : 192.168.1.1 DHCP Server . . . . . . . . . . . : 192.168.1.1 DNS Servers . . . . . . . . . . . : 192.168.1.1 Lease Obtained. . . . . . . . . . : 06 March 2005 01:03:44 Lease Expires . . . . . . . . . . : 06 March 2005 02:03:44
C:\>
DWL-G122
DWL-G122
Well there is no difference, so it looks like the router is talking ok to you. Have you checked for any firmware updates for your router?
