Hey,
Im using an edimax AR-7024Wg router and up until the other day had wireless devices (Wii and DS) connected to it fine. Now, since a powercut which meant the router was reset, neither will connect. As far as I can see all the settings are now correct, DHCP server is enabled under LAN config, WEP key is entered correctly into the devices..I'm stumped.
However, there is an option for a DHCP client under WAN config, but it's set to "disabled" and if I change it to "enable", it just defaults back to "disabled" again. Could this be the problem? Under this setting theres also a box for "Host Name" which is currently "UK", again, is this it?
Any advice would be greatly appreciated!
Thanks
Aimee
