Hi, I'm wondering if anyone else has had this problem with a DI-514. Basically up until yesterday, my wireless network was working fine. Yesterday, I had to disconnect and unplug the router while I was moving some stuff around. When I plugged everything back in, I couldn't connect to my wireless router (D-Link DI-514) anymore! I am able to get it to work whenever I power-cycle the router. But after about five minutes, I lose the signal again (and the WLAN light goes out too). I've tried re-updating the router firmware and my wireless card drivers (even though I already did that and had it working). I tried re-setting my router to factory defaults. I tried taking the router to a friend's house with a cable modem - same problem. I also tried changing channels on the router, I tried Channel 6 and 11 with no luck.
Brief specs: Windows XP Pro. My connection is a T1 (dorm room - but the router works fine while hard-wired to my ethernet card, and I can connect to other wireless networks nearby). I have no problem accessing the Internet when connect my ethernet card (same computer) to a port on the router - I just can't access my router wirelessly here or at home. I'm thinking it must be some signal problem where the router stops broadcasting after a few minutes, but I can't figure out why this is happening all of the sudden when it was working a couple of days ago. I also know it's not my wireless card since I can connect to wi-fi networks on campus, just not my own.
Any help is greatly appreciated.
