Hi, I'd like to share an internet connection between two houses that are 2 houses appart and in front one of the other. Is there a simple solution cause I don't think my wifi router will be enough?
Thanks
Patrick
Thanks
Patrick
Take a look at hyperlink technologies
In conslusion, if you a kid your going to need the help of an adult. This is not a simple process and you need to observe safety when getting on latters and such. Falling off a roof can kill you. I personally would like to stay alive as long as possible. So please make sure you know what your doing or ask for help.
