Hi!
Is it possible to use a Wireless Access Point in order to connect a device to an already existing Wireless Network? I mean, configure the Wireless Access Point and then connect a patch cable between the device and the Wireless Access Point.
I think that my question can be simplified into: Is it possible to get a Wireless Access Point to communicate with other Wireless Access Points/Routers? If not, what kind of device should I use instead (an ordinary Wireless Network Interface Card is out of the question).
Kind regards tmk
