Connecting outdoor antenna.
Hello -
I have my SOHO WiFi set up using a Dlink G604T with the usual dipole arials and it all works fine, including the printer.
The G604T is permanently on, and any computer can start and be instantly networked and online.
The challenge is to connect an exterior +12dbGain directional antenna to my existing net so I can read a security camera signal from a distant building. This is to be permanently on too, so my preference is to somewhow feed the signal into the G604T router.
The G604T has one only antenna.
compac
So another AP on the network (about $50 to $60) is out of the question? Due to budget or not understanding that the router fuction can be turned off in mst APs on the market?
If the budget thing isn't the issue, just add another AP to the current network (plugged into the switch, assign it an IP outside the range your DHCP server is handing out and problem solved. One extra advantage you can make sure the 'new' AP has a connector on the back that is easy for you to attach the antenna. One thing you might investigate if budget isn't too strict, a weatherized AP, the closer (wire wise) you can get the AP to the antenna the better your results will be.
fundamentalism, fundamentally wrong.
Rico
Hey Thanks Rico
Sorry to be thick, but can't see what you mean, If I hook up the outdoor antenna to the AP, how can it then send the signal on to my existing WAP? Would I need a WAP with 2 antenna connections?
"plugged into the switch" - do you mean physically (LAN?) wire it to my WAP?
compac
Ethernet cable from old AP with switch to new AP eternet port (crossover maybe required, but with newer switches, unlikely)
AP --------- AP cat5^
Rico
This is a brick house where I have my SOHO, and the reason for the wireless net is because cat5 cables are not practicable.
I will have an exterior directional antenna off the front corner of the house where it can get LOS signal from the camera, the DLink WAP is at the other end of the building.
I can understand the AP --------- AP cat5^ link OK, but the whole point of this exercise is to avoid the cat5 cable and use wireless.
compac
It can't be done - see my many attempts to have the same effect, though in a different setting...
Most recent failure was the thread titled AP access hardware, 1-18...
L8R
Skip
Skip Gundlach
Connect a 2nd AP to your network with powerline networking; e.g., IOGEAR GHPB32W4 Powerline Networking Kit
John Navas
