Connecting a wired router to a WAP?
Hi ,
I'm hoping someone out there much smarter than myself can help me out. At the moment I currently have my home computers connected via ethernet cables to a wired router which connects to my cable modem. Now unfortunately I have the cable modem sitting on my computer desk on one side of the room, and the cable outlet is on the other side of the room so that means I have this cable running across the floor along the length of the room. Now this is physically unacceptable, and I would very much like to get rid of floor cables.
My current computer setup is one PC(dual boot linux/win98) and one iMac attached to my wired router.
The trivial solution would be to buy a wireless router to place beside the cable modem which would be beside the cable outlet on oneside of the room and insert wireless cards into my desktop computers. The problem with this is I don't know if my PC operating systems would like wireless cards, or even where to find a wireless card for my wifes iMac. (ie that would mean buying a router and two seperate wirelss cards, a little out of our financies right now)
What I was hoping to do was to place a wireless router( or some other wireless product) beside the cable outlet on the far wall, and some how wirelessly connect it to my regular router which I have setting on my computer table top.(I would like to utilize my regular router because I know both of my computers work when plugged into it)
So my questions are (a) is this physically possible? (b) if so what would I need to buy to do it?
Many thanks,
Jeff
Jeff K deJong
What I am thinking is ... setting up a wireless bridge - but it would be the same price or even more expensive to getting a new router and cards.
Using two WAPs (wireless access points) you would plug one into the router, and on the otherside of the room connect the other WAP to an Ethernet switch. The computers are connected to the switch, which is connected ot the WAP, which talks wirelessly to the other WAP, which is connected to the router, which is connected to the cable modem.
pc / mac switch wap .... wap router cable modem internet
means wired ..... means wireless
I have this setup going to connect two buildings together - using Linksys access points
riggor
On Fri, 28 Jul 2006 19:01:59 -0600, Jeff K deJong wrote in :
You could use a wireless access point next to the cable modem, and a wireless client bridge next to your wired router. Powerline networking would also work.
John Navas
Move the cable outlet. Seriously, the wire's cheap and it's probably the least expensive solution overall.
Buy a cheap wifi router and a single USB wifi adapter. Most work with both windows (post-98) and the MacOS. Check the vendor's website FIRST and see that they claim to have drivers for whatever version of OSes you're actually running. Then swap the adapter between the computers and see that they actually get wireless coverage.
You could then use one or the other computers, with their wifi link to the base, as a bridge to the other computer. But this would then end up requiring that bridging computer be turned on all the time. That and introduce some potential for network routing issues. It "should" work but connection sharing isn't without it's issues and I'd recommend not choosing this option.
By the time you buy this second router and the bridge to connect to the existing one you'd probably be more expensive than a router and two USB interfaces. As for working with the existing computers, anything new will certainly work with it too. If you want to keep using the current router then buy a wifi "Access Point" or a router that can be specifically 'dummied up' to behave like an access point and not as a full router. You'd then plug that access point into your current router and continue using it's connection to the cable modem through it. Shop the bargains, and buy from a local retailer than has a return policy. That way you're covered should it just "not work".
I'd start by taking a serious look at just re-routing the cable coax wire. Then step up to an access point/router and single USB interface to get things tested.
-Bill Kearney
Bill Kearney
