yes, it will work, i plug my smc wireless router into my linksys G works fine
- Vote on answer
- posted
18 years ago
If you have a Linksys wireless G router connected to your cable modem can you connecte a Linksys wireless b router to the G wirelessly???
No. The right answer is to use WDS (wireless distribution service). That means that both of your unspecified Linksys routers need to be the same type and support WDS protocol.
Can't WIRE them together... Will the see eachother wirelessly?
"WIlly Ci" wrote:
