This is one device where you should AVOID reading included paper manual - there is a detail manual on included CD. The setup:
- don't read paper manual
- From the included CD start the utility program. This program will show you the IP address assigned to the Access Point.
- open a browser and point it to the above IP address
- you will get logon screen. On a first time use user name and password field empty.
- now you will get detailed configuration screens.
- Try to figure correct values.
Zalek
