I have a the Linksys WRT54G Ver. 2 . I am trying to test for signals. I was told that I need the router in client mode. Is this true and what would I need to get this thing working. I have been reading on this for quite awhile with no success in getting any results. Any help would be appreciated.
Amazing. Thanks for including the WRT54G hardware version number. That's a first and deserves a detailed answer. v2 should work just fine.
Basically true. The stock Linksys firmware does not have a wireless client mode. In order to get this feature, you'll need to replace the stock firmware with a Linux based 3rd party alternative such as:
There are others. See:
When you say "trying to test for signals", are you looking just for other access points or are you also looking for clients? If sniffing for clients, look into Kismet Drone. If access points, DD-WRT, and probably the others have various sniffers built in that can be used in normal access point mode. For example: /sbin # site_survey buflen=[480] version=[107] count=[3] [ 0] SSID[ NETGEAR] BSSID[00:1B:2F:4F:60:AC] channel[11] rssi[-89] noise[-98] beacon[100] cap[421] dtim[0] rate[12] enc[Open] [ 1] SSID[ default] BSSID[00:15:E9:68:28:A2] channel[ 6] rssi[-81] noise[-89] beacon[100] cap[431] dtim[0] rate[12] enc[WEP] [ 2] SSID[ moo] BSSID[00:13:10:EA:0B:97] channel[ 6] rssi[-93] noise[-89] beacon[100] cap[401] dtim[0] rate[12] enc[Open]
There are also HTML front ends that produce more readable output.
DD-WRT v23 SP3 and OpenWRT include Wi-Viz 2.0:
which provides one of the strangest site survey display I've ever seen. Instead of the usual table or chart, Wi-Viz has a moving display that never seems to stay put. However, it does show client radios in infrastructure mode.
Like i said ,I have been reading up on this for a long time! I will go through your instructions and study more. I am wanting to test free wifi spots for free internet. I pay for my internet. I want to be able to learn this stuff and help others learn.
Thanks once again!!!
