Wireless Networking cisco dish v grid antenna
Subject Author Date
cisco dish v grid antenna tg 06-06-08
Posted by tg on June 6, 2008, 6:29 am
I want to get a high gain directional wlan antenna (it will be mounted in a
fixed
position, not mobile) and I was thinking about a Cisco AIR-ANT3338 solid dish -
they're
pricey but I expect excellence from Cisco. I've also seen these grid antennas
about which
are a fraction of the price and yet advertise the same gain levels and narrow
beamwidth.
Is there an advantage to getting the Cisco or am I just paying for the name?
Thanks for
any advice.
Posted by ps56k on June 6, 2008, 9:58 am
> mounted in a fixed position, not mobile) and I was thinking about a
> Cisco AIR-ANT3338 solid dish - they're pricey but I expect excellence
> from Cisco. I've also seen these grid antennas about which are a
> narrow beamwidth. Is there an advantage to getting the Cisco or am I
> just paying for the name? Thanks for any advice.
why ?
what will it be locally connected to, and how far is the cable run ?
what will it be pointed at ?
Posted by tg on June 6, 2008, 12:04 pm
> why ?
the dish will be connected to a PCI wireless card in a pc
cable run will be about 10 meters or less
it will be pointed at another location that has an access point - I want a
direct
connection to the other building, independent of the internet.
Posted by LR on June 6, 2008, 12:23 pm
>> why ?
direct
If your PCI card has a power output of approx 13 dBm.
The Cisco Antenna is 21dBi.
If you use 10 metres of LMR400 to connect them, say 2.5dB loss.
That would give you 13+21-2.5 = 31.5dBm which is 11.5 dBm more than you
are allowed in the UK.
You will need to consider changing antennas on both ends of the link to
stay within the limits, and for the link to be viable.
Posted by tg on June 6, 2008, 12:54 pm
> tg wrote:
ps: I also have a fairly strong access point so I might at some point swap the
ends around
and connect the dish/grid to my access point. It's just a case of spending my
money wisely
that's all - I don't want to spend hundreds of pounds on a dish antenna if a
grid antenna
will do exactly the same thing.
Similar ThreadsPosted
cisco dish v grid antenna June 6, 2008, 6:29 am
Re: anyone out there using a parabolic grid antenna? June 9, 2008, 6:46 pm
Re: anyone out there using a parabolic grid antenna? June 9, 2008, 6:54 pm
Re: 2.4 Ghz 24dbi Grid Antenna No Signal!! November 12, 2007, 3:25 pm
Re: 2.4 Ghz 24dbi Grid Antenna No Signal!! November 15, 2007, 6:46 am
Re: 2.4 Ghz 24dbi Grid Antenna No Signal!! November 15, 2007, 6:49 am
Re: 2.4 Ghz 24dbi Grid Antenna No Signal!! November 15, 2007, 7:01 am
Re: 2.4 Ghz 24dbi Grid Antenna No Signal!! November 19, 2007, 1:45 pm
Re: 2.4 Ghz 24dbi Grid Antenna No Signal!! November 26, 2007, 5:23 pm
15dbi grid antenna (Australia) ending soon March 2, 2006, 5:39 am
Parabolic Dish Wi Fi Antenna November 9, 2005, 12:37 pm
What Feed antenna for Dish? June 25, 2008, 5:57 pm
Wooden parabolic dish antenna May 4, 2005, 2:08 pm
Can an old DirecTV Dish seriously be used as wifi antenna? August 19, 2006, 9:03 pm
Cantenna, Dish, Large Antenna or "Other" September 5, 2008, 2:50 pm
