Hi.. hoping someone can assist..
We have a few Cisco AP1200's that doesn't seem to be accepting any connection from the clients.
Here's what I've discovered so far..
- event logs doesn't show any info or errors
- I can't see the AP in netstumbler
- running Radio Carrier Busy Test, it's showing 100% for all freq.
I've tried to reset the ap to factory default - still using VXWorks but
the default Tsunami SSID or anyting is not showing up in netstumbler.
I've upgraded to the latest version of IOS - same results - no results
-> no clients connect, no error or any info on event log (except once in awhile there is a radio down/reset/up). Only difference is Carrier busy is not 100% - all freq is in the 60-70% busy.
Eventhough carrier busy is high %, net stumbler is picking up only 1-2 APs using channels 1 or 11. I tried manually setting channel to 6 but still no clients are connecting or netstumbler is not seeing the AP.
Any help would be greatly appreciated!
Thank you..
