~ I have a Cisco 340 wireless card in my pc. Works great with the Cisco ~ A/P. I have a Symbol AP-4131 a/p.. I was trying to get the cisco 340 ~ to SEE the Symbol AP... What do I need or CAN the Cisco work with the ~ Symbol??? ~ ~ Thanks
The 340 client should interoperate fine with any standards-compliant
802.11b AP. In addition to the 802.11b standard protocols, it supports 104-bit static WEP (aka "128-bit WEP"), as well as WPAv1 TKIP (for which you would need to use a WPA EAP supplicant or a WPA-PSK supplicant such as Windows XP WZC.)How do you have your Symbol AP configured? What is its SSID? Is it broadcasting the SSID in beacons? Is it configured for static WEP? If so, is it 40- or 104-bit WEP? Have you configured the WEP key? Is it configured for shared key or open authentication?
Once you find that out, add a profile in ACU to match the Symbol AP's settings. Then activate the Symbol profile within ACU or by right-clicking the ACM icon in the system tray (i.e. the square icon with the concentric arcs radiating up from a point.)
To reinstall/upgrade/downgrade the code for the 340, go to
See
Cheers,
Aaron
