Cisco 1242 access point web management timeout.
I am setting up a couple of these and the web management timeout is not much more than a minute which is really annoying. I looked through the manual and the various menus and haven't found a setting to increase the timeout.
Any ideas?
George
I don't know for sure if this is implimented in the 1242 Access Point but try it anyway:
idle-timeout (WSMA)
To set a time for the Web Services Management Agent (WSMA) profile to keep the session alive in the absence of any data traffic, use the idle-timeout command in the WSMA listener configuration mode or the WSMA initiator configuration mode. To disable the idle-timeout, use the no form of this command.
Examples: idle-timeout minutes no idle-timeout
Jeff Liebermann
You mean you are being asked to reauthenticate on a frequent basis?
One tip I can offer is to use IE rather than some other browser. For some reason, IE is much faster with the AP GUI.
Beyond that ... I don't quite know offhand. Try in the comp.dcom.sys.cisco group if you need more help.
Aaron
Aaron Leonard
Thanks, not sure how to get there or it isn't implemented.
George
Yes
I tried both IE and Firefox on different machines and timeout is the same.
George
