Changing Network SSID Blocks Incoming Mails To My Inbox?
Threaded View
I set up a home wifi network using a D-link boradband router and lavet the
SSID as default. Everything runs smoothly, no problem with incoming and
outgoing mails.
On 26the Dec I changed my network SSID to a specific name. Now, while i can
still send outgoing mails, my incoming mails from 26 Dec onwards are all
stranded in the mail server and could not come into my inbox. I am using
Outlook Express ver. 6.  I realised this when someone told me to check my
pop3.log file and sure enough all incoming mails are stuck in the server and
cannot come in. However i can still receive incomg mails sent from within
the network.
Is it because the SSID has been changed and some related settings need to be
changed at the same time? Or is it the mail quota on the server is full? Can
someone help? TIA
Re: Changing Network SSID Blocks Incoming Mails To My Inbox?
>outgoing mails.
>the network.
>someone help? TIA
I could be wrong, but the SSID is simply the name of your wireless
network.  (service set ID)  I've changed my SSID several times over
the years and have yet to experience a mishap because of the change.
Therefore, your changing of the SSID should not interfere with
anything.  To be on the safe side, when you changed the SSID in your
route/AP  settings, did you enter the new SSID into the card's
configuration menu?
>> lavet the SSID as default. Everything runs smoothly, no problem with
>> incoming and outgoing mails.
>> while i can still send outgoing mails, my incoming mails from 26 Dec
>> onwards are all stranded in the mail server and could not come into
>> my inbox. I am using Outlook Express ver. 6.  I realised this when
>> someone told me to check my pop3.log file and sure enough all
>> incoming mails are stuck in the server and cannot come in. However i
>> can still receive incomg mails sent from within the network.
>> need to be changed at the same time? Or is it the mail quota on the
>> server is full? Can someone help? TIA
> configuration menu?
That's the typical symptom of changing the wap's ssid but not rebooting the
machines on your network
On Sat, 1 Jan 2005 19:39:53 -0800, Peter Pan spoketh
You do NOT have to reboot your (Windows) computer when changing the SSID
on your wireless network connection.
Lars M. Hansen
www.hansenonline.net
Remove "bad" from my e-mail address to contact me.
"If you try to fail, and succeed, which have you done?"
>> rebooting the machines on your network
> SSID on your wireless network connection.
> Lars M. Hansen
No you don't. But if you want to access it after changing that (or the
workgroup names), it a whole lot easier to just reboot rather than connect
to a new network. I always wonder why people are so deathly afraid to power
off or re-boot... It works absolutely no matter what, and it fixes probably
90-95% of the errors..
On Sun, 2 Jan 2005 12:19:07 -0800, Peter Pan spoketh
There's absolutely no relationship or even similarities between changing
the SSID and changing the workgroup name. Changing the SSID is simply a
minor change in what name the wireless client uses when connecting to a
network. Changing the workgroup name is a major change in what name the
operating system uses when participating in a network.
There is absolutely no need to reboot your computer after changing the
SSID. There are no benefits to doing so, and there's little point in
suggesting that it in any way, shape or form would help or even rectify
the OPs original question is way of.
Changing the SSID on a WLAN does in no way affect connectivity. Once the
change has taken place, the client should get an IP address from the
DHCP server, and connectivity to everything should be restored to the
way it was prior to the SSID being changed. The fact that the OP cannot
get his e-mail after changing the SSID is most likely coincidental.
Lars M. Hansen
http://www.hansenonline.net
(replace 'badnews' with 'news' in e-mail address)
On Sun, 02 Jan 2005 22:30:48 -0500, in alt.internet.wireless , Lars M.
This is all true
>SSID.
Yes
I disagree with this tho - its very likely that some other config change
has been made and rebooting the box will probably help.
Mark McIntyre
CLC FAQ <http://www.eskimo.com/~scs/C-faq/top.html
CLC readme: <http://www.ungerhu.com/jxh/clc.welcome.txt
----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==----
http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+
Newsgroups
----= East and West-Coast Server Farms - Total Privacy via Encryption =----
On Mon, 03 Jan 2005 11:18:58 +0000, Mark McIntyre spoketh
>This is all true
>>SSID.
>Yes
To our knowledge, nothing else has been changed. If everything is the
same except the SSID, then it should only take a matter of minutes for
the network card to recognize the change and connect to the network and
obtain an IP address. Since the OP can get internal mail, it appears
that he does have a successful network connection.
Lars M. Hansen
On Mon, 03 Jan 2005 07:38:41 -0500, in alt.internet.wireless , Lars M.
This does'nt invalidate the suggested fix...
Mark McIntyre
Newsgroups
>>> change has been made and rebooting the box will probably help.
>> for the network card to recognize the change and connect to the
>> network and obtain an IP address. Since the OP can get internal
>> mail, it appears that he does have a successful network connection.
Hate to tell you mr THINKS he knows it all (lars not mark), but that's
exactly the attitutude I love to see as a consultant. I get to charge
hundreds of bucks to fix the errors people like you claim can never
happen...Heres a hint, If you have a WAP/Router, and change the ssid on the
wireless part, it doesn't effect the wired parts of the network, but if your
mail server is wireless and waiting for someone to hit "connect" (SP2
doesn't autoconnect by default), it will do exactly as the OP said (you can
email to others on the network, but not get stuff from the wireless node
that talks to the outside mail service, until it is re-connected, and the
easiest way to train dumb minimum wage employees to handle a problem, is to
teach em one thing... reboot... and then if it still doesn't work, call
support)
Taking a moment's reflection, Peter Pan mused:
| the wireless part, it doesn't effect the wired parts of the network, but
| if your mail server is wireless and waiting for someone to hit "connect"
| (SP2 doesn't autoconnect by default), it will do exactly as the OP said
| (you can email to others on the network, but not get stuff from the
| wireless node that talks to the outside mail service, until it is
| re-connected, and the easiest way to train dumb minimum wage employees to
| handle a problem, is to teach em one thing... reboot... and then if it
| still doesn't work, call support)
    That still doesn't have anything to do with the client, which is the
topic ... and where did the OP state that he has a local mail server that is
locally connected to his wireless network?
> the topic ... and where did the OP state that he has a local mail
> server that is locally connected to his wireless network?
He didn't.. He just said he could get regular intracompany email, but none
from outside ISP. That is a typical symptom of wired or wireless that can
talkto/see each other, but not outside. Changing an SSID (see the subject)
won't matter, unless you have a wireless mailserver.
On Mon, 3 Jan 2005 09:03:52 -0800, Peter Pan spoketh
>support)
Funny as you may thing it is, as a fellow consultant, I also see that
rebooting solves a number of issues. That's not the heart of the matter
here; the point that I have been trying to make is that:
1) Changing the SSID probably didn't cause this problem, and
2) There's no need to reboot after changing the SSID.
Even, as you say, SP2 doesn't reconnect after the SSID has been changed
on the WAP, that can easily be resolved by changing the SSID on the XP
machine as well...
Lars M. Hansen
> matter here; the point that I have been trying to make is that:
> changed on the WAP, that can easily be resolved by changing the SSID
> on the XP machine as well...
> Lars M. Hansen
One important word in that.... "probably". Sure it probably didn't, but
there IS a possibility, no matter how small that percentage is, and a reboot
would let him know for sure, and may pop up other errors that weren't known
and can be fixed, not to mention reset things to a known state... Sorry, A
reboot usually only take a minute or so, resets things to a known fresh
state, and gets rid of any temp errors/glitches? The OP said he has been
dicking with it for 4 days (5760 minutes).. whats the big deal about trying
something that only takes 1/5760 th of the time the error has been there,
and may fix it? I can't understand anyones hesitancy to power
cycle/reboot... Over the years I've gotten many calls and pages at 2 or 3
AM, and before I get out of my nice warm bed, I always tell the person on
the phone to turn it off and back on. Only had to get up and go in once.
The difference (as I see it), is I try and do things with the "garbage truck
theory" in the back of my mind (I get hit and killed by a garbage truck, and
someone ELSE has to make it work), whereas I keep seeing things here like "I
can", "probably not" etc. assuming they will actually be there hands on,
rather than make it easier for non pros to do things. Actually, now that I
am older, I think of it in a less morbid way (no garbage truck and dying), I
think what if I am on vacation in another country and it dies? What can I
tell someone to do over the phone so I don't have to travel back a few
thousand miles.
Reminds me of the car scenario... Do you leave it running for days making
strange noises/doing wierd things, or turn it off, restart it, and try
again?
<quote Peter Pan>
the
your
can
node
the
is to
support)
</quote>
I am sincerely surprised that you get any work as  a consultant with
the way you talk to others but I guess the low end market is less picky
in regards to who they let work for them, but anyway
Also, as a "consultant" I am sure you know that basically you do not
have enough knowledge to actually pinpoint the cause of the issue.
Let us sum up:
1. The SSID was changed on the AP
2. The connection between the Client and the AP is functional as mail
can be sent, as well as  received internally
As such, the wireless connection is functional.
Some questions are left open:
What is the network toplogy like?
i.e. client -> AP -> LAN(including mailserver)
Can you access the mail server ? I.e. telnet port 110/25 on the mail
server
Do the relevant logs show anything? on the AP or the mail server? What
does a Packetsniffer show?
<quote>
Now, while i can
all
</quote>
How do you know they are in the inbox? on which server?
Without knowing how the network. is composed and the email server
location and method of access all this is pure guesswork.
<quote peter pan>
</quote>
makes no sense at all, reconnect to what?
It is connected to the LAN as internal email works fine, and
bidirectional connectivity seems to be present.
Where should it reconnect to?
You make no sense, no offense intended
regards
dc
On Mon, 03 Jan 2005 16:39:46 +0000, Mark McIntyre spoketh
Rebooting may fix the OPs problem. My point was:
1) Changing the SSID was most likely not the cause of the problem, and
2) Changing the SSID does not require a reboot.
Lars M. Hansen
On Mon, 03 Jan 2005 17:52:00 -0500, in alt.internet.wireless , Lars M.
Agreed.
>My point was:
Agreed x2. However what the OP wanted was to fix his problem, not have a
discussion about the technicalities of changing SSIDs.
IME people very often come to technical groups with the wrong question,
based on a half-understanding or complete misunderstanding of the problem.
Its often more productive to solve their real problem than discuss their
imaginary one!
Mark McIntyre
Newsgroups
On Mon, 03 Jan 2005 07:38:41 -0500, Lars M. Hansen
Further, if one wants to force the refresh, simply right click the network
status icon on the taskbar (or go through the control panel->networking),
and select "repair".  Windows FM happens (buffers flushed, a new DHCP
address drawn, etc) and the new connection is established in seconds.
I frankly doubt that would do anything here, though.  XP, at least is very
quick to reconnect to the same channel even if the SSID changes.
Over the Christmas holidays, I did a 1500 mile looping wardrive (aka
"vacation") around Florida using the LinkSys WUSB54GS USB2 WiFi adapter
mounted in one of my motorhome's skylights.  In the more populated areas
NetStumbler would announce more than 100 WAPS/mile, about 99% of them open
and with default SSIDs.  Almost all were on the default channels of 6 or
11.  I could make a connection on a channel, fetch my email and then watch
XP connect to one WAP after another as I drove along.  It would change
from one to another sometimes in just a couple of seconds.  That little
info window would pop up announcing one SSID after another.
There is something else going on here other than just changing SSIDs.
perhaps the client adapter needs to be told to rescan the bands.  LinkSys
calls this a "site survey", others call it a "scan".  In any event the
client software should discover everything within range and either connect
automatically or give the user the option of selecting an AP.
John
John De Armond
johngdDONTYOUDARE@bellsouth.net
http://bellsouthpwp.net/j/o/johngd /
Cleveland, Occupied TN
| power off or re-boot... It works absolutely no matter what, and it fixes
| probably 90-95% of the errors..
    Fear has nothing to do with it.  It's usually not necessary and
therefore a waste of time. I can reconnect to my WAP after changing the SSID
within 5 seconds.  Rebooting can take up to a minute and a half.
>> the workgroup names), it a whole lot easier to just reboot rather
>> than connect to a new network. I always wonder why people are so
>> deathly afraid to power off or re-boot... It works absolutely no
>> matter what, and it fixes probably 90-95% of the errors..
> the SSID within 5 seconds.  Rebooting can take up to a minute and a
> half.
Maybe that's part of it. Maybe *you* can do it in 5 seconds, but try doing
it on a support call at 2AM with a minimum wage person that barely speaks
english.
Site Timeline
