Hi I am currently running two PC's, one Win XP Pro the other XP Home, I have them set up for ICS over a Wireless system, set up in what I think is a pretty standard configuration.
The Internet cable is connected to the modem which is connected to the Wireless Router, the XP Pro PC is connected to the Router by a Network cable and the XP Home PC connects by a USB wireless Network Adapter.
Now I have to move and the cable outlet will not be in the room where I need the PC's to be kept.
Is it possible to set it up so the Cable goes to the Modem which then is connected to the Wireless Router and then connect both PC's via a USB wireless Network Adapter?
If so please give me some information on how to set it up.
thanks and regards
Daniel
