hello some suggestion for one router wifi that is possible to change the radio power ? and limit it to minimum? which one?
thanks so much
--- news://freenews.netfront.net/ - complaints: snipped-for-privacy@netfront.net ---
thanks so much
Please repost with more information, including the manufacturer and model of the wifi hardware you are using.
Ben
Il 06/11/2014 17:09, Ben Myers ha scritto:
I Ben I haven't a router wifi I want to buy a new one with this features
thanks a lot
Why do you want to limit power? It does little good as a security precaution. For Wi-Fi, the only real security is encryption. Once you have done that, the other supposed security measures -- hiding the SSID, filtering by MAC, reducing power -- are pointless.
The Buffalo wzr-hp-g450h has a power setting, but it is unknown if the power is continuously variable.
where did he say it was for security?
not necessarily.
