Does anyone know of a way to change the MAC address of your computer? There is a website I use where if you search too much they block you from anymore searches for a 24 hour period. They don't block the IP, but rather the MAC, so if you are able to change the MAC address you will be able to use the site again. My friend is able to do it through his router (I guess his ISP doesn't register his MAC), but whenever I try to change mine I totally lose my connection. Anybody know of an easy way to do this? TIA
- posted
17 years ago
