Hi, I have a Linksys WRT54G wired to my desktop pc. Both my and my fiancé's laptops have no problem accessing this router using wireless. My daughter is home from college and I picked up a WUSB54G (V4) to get her Desktop PC on the network. All these machines are running XP Pro SP2, except my daughters, which was SP1. The router is set up to use 128 bit WEP key #3.
When I tried to set the USB wireless adapter on her PC it would accept the
26 character key but would not connect. When I edit the profile the key is only 8 characters. At a Linksys Tech's suggestion I upgraded the XP to SP2. He also said to use the XP setup and not the Linksys utility. I tried that and it still won't connect and still only displays 8 characters of the key. Shouldn't I be able to save the 26 character key?I've tried the key as both 'auto' and 'shared' and still no luck. I'm using 'Infrastructure' mode as I want it to connect to the router to get on the network. Is there a setting on the router that I need to enable to do this?
Thanks for any help or suggestions, Jon
