The PC's used to be on a peer to peer network using win2k. They are set up to obtain ip addresses automatically. The laptop cannot see the pc(s) attached to the router.
Here is the ipconfig for the laptop;
----------------------------------------------------------- Windows 2000 IP Configuration
Host Name . . . . . . . . . . . . : FishSauce Primary DNS Suffix . . . . . . . : Node Type . . . . . . . . . . . . : Broadcast IP Routing Enabled. . . . . . . . : No WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection 2:
Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Motorola Wireless Notebook Adapter W N825G Physical Address. . . . . . . . . : 00-0C-E5-52-B3-8D DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes IP Address. . . . . . . . . . . . : 192.168.0.100 Subnet Mask . . . . . . . . . . . : 255.255.255.0 Default Gateway . . . . . . . . . : 192.168.0.1 DHCP Server . . . . . . . . . . . : 192.168.0.1 DNS Servers . . . . . . . . . . . : 192.168.0.1 Lease Obtained. . . . . . . . . . : Tuesday, May 02, 2006
5:06:53 PM Lease Expires . . . . . . . . . . : Tuesday, May 09, 2006
5:06:53 PM
And here is the ipconfig for the pc;
Host Name . . . . . . . . . . . . : Lemongrass Primary DNS Suffix . . . . . . . : Node Type . . . . . . . . . . . . : Broadcast IP Routing Enabled. . . . . . . . : No WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . : Description . . . . . . . . . . . : D-Link DFE-538TX 10/100 Adapter Physical Address. . . . . . . . . : 00-50-BA-57-0A-35 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes IP Address. . . . . . . . . . . . : 169.254.89.123 Subnet Mask . . . . . . . . . . . : 255.255.0.0 Default Gateway . . . . . . . . . : DNS Servers . . . . . . . . . . . :
END
hrifraf
