Cannot route ports for RDP
Hi I use Belkin wireless router at home. (Firmware Version: F5D7230v4_UK_6.00.14 , Hardware: 4.00.01). Sometimes I need to use my home PC from my work through Microsoft RDP. To have my internal home network more secure - I decided to connect with the RDP using port routing (for expample 13390 external) -> 3389
-internal). Here is the link how my configuration looks like:
Unfortunately - there is no way to do it so :( When both ports (external and internal) are the same - it works great, but when I try to change one of them - no way!
There is no personal firewall installed. When connecting in RDP client
- I remember to enter the port number (for example: my.host.pl:3390). I also know how to change default RDP listening port in Windows (in windows registry key). So the problem is somewhere else.
There is no firmware update for this product.
Please - help me: where should I look for solution? Thanks in advance
Marek
Marek Wojtaszek
So just change, or add, the port the PC uses to accept the RDP sessions. You're not stuck with just 3389. I've seen setups where several outside port numbers were each redirected into individual PCs, each running an RDP server on that corresponding port. Thus the router just redirected port A to IP address 1, port B to address 2, etc.
Search technet for how to add ports to RDP.
Bill Kearney
